bootfahrer0815 avatar image
bootfahrer0815 asked
virtual switch (vs): Is it possible to switch it manually?
I use the VS to ignore the AC-input (shorepower) or not. If I´m on holiday and see, that the SOC of my batteries is too low, it would be fine, if I could activate the VS remotely, so that the shorepower can load my batteries. I don´t want to wait sometimes, that the system will switch the VS depending on my configured conditions for switching.
Thanks for help!
Greetings!
Rainer
VEConfigure 3shorepowervirtual switch
Alexandra avatar image
Alexandra answered ·
@Bootfahrer0815
If you have programmed using the virtual switch tab, I have not seen a solution.
you can use assistants however like the ignore AC with generator assistant or the ignore ac assistant and use the GX relay to override the conditions.
There are a few posts with adaptations of its uses.
https://community.victronenergy.com/questions/85215/can-gx-generator-startstop-feature-control-ac-in-o.html
https://community.victronenergy.com/questions/52652/multiplus-mains-led-flashing-1.html
there are quite a few other ideas, it takes a bit of fiddling to get right.
