Herve RV Nizard avatar image
VE configure ESS settings change problems
Good day. I am facing a problem trying tyo set some settings on ESS via VE configure.
When I reach the VE configures, Virtual switch tabs, the values are greyed and cannot be changed ?
I probably did something wrong, but cannot figure out what ! I tried many other changes, but still non editable ? Any idea ??
This is the tab where I cannot change the settings : "when loads higher than " .....
Thanks
ESSVEConfigure 3virtual switch
You can use either assistants or virtual switch functionality, but not both.
I think all virtual switch functions can be recreated with assistants, but not as easily.
I am still working on this:
https://docs.victronenergy.com/veconfigure.html
