upperyv avatar image
upperyv asked
MultiGrid 24/3000/70-50 firmware v497 issue
Hi there,
With the latest firware version, I'm having an issue when uploading a different VEconfigure profile. I was able to change the profile without a system outage. With the latest firmware (and the version before it which I used for a week or so), when I change profiles the power is off for a few seconds. This creates an issue with getting everything rebooted and connected again. Is there something I can do to stop this from happening or do I just need to revert back to an older firmware.
I bit of of backend info if you care for it or you're wondering why I need to change profiles:
I'm running a 1380AH 24 V flooded lead acid battery bank. I need to equilize every 20 days ideally. To meet the battery manufactures specification or an equalisation charge I need to change the charge voltages from the regular absorption voltage. So I can it so the multigrid think its in bulk or absorp, but the voltage is set to equilise. I haven't figured out another way to do this without changing profiles every 20 days; the built in equalize feature of the multigrid doesn't work with the requirements of our system.
Regards,
UYV.
firmware updateVEConfigure 3lead-acidmultigridequalisation
denzel avatar image
denzel answered ·
I have been running these unit since 2017 and if i used the "Remote VEConfig" to upload a change it rebooted the entire system . If you using the MK3 cable direct to the inverter when sending a change you have 2 options to only send modified settings , this wont reboot the system, the other option is to send all settings and this will reboot the system. This has been the case post version 497.
