chenirl avatar image
chenirl asked
Split phase victron quarrto 3000/48 not charging from AC
Hello, I hope someone out there can help.
the system in question is installed on a bus with Solar but currently located in a very shaded area, from time to time we need to charge from grid.
the system has a Cerbo GX.
also in setup we disabled "Switch as Group". As suggested in other posts. As we are triying to charge from a single 120V ac input (AC Input 1)
Additionally it is in VS it is setup to start charging from ac when battery voltage drops below a 56 volts.(condition was met).
when connecting to grid, it shows volts and hertz but doesn’t start charging.
Other info:
There’s a CAN bus BMS connected and it controls solar charging perfectly.
I’ll be glad to provide any other data.
Thanks!
MultiPlus Quattro Inverter Chargerbattery chargingchargeracvirtual switch
@chenirl
Disable virtual switch for now to rule out that being the issue. And see if it just connects that way and charges.
As for the charging, you will need to rule out can bus being the issue or the settings on charger tab.
VE Configure/Virtual Switch
Ignore AC input using the Generator Assistant
MultiPlus Product page Quattro Product page
MultiPlus 230V ManualQuattro 230V Manual
MultiPlus 230V Datasheet Quattro 230V Datasheet
VE.Bus Error codesVE.Bus configuration guide
Chargers.
VictronConnect VE.Bus charging manual
