pointer avatar image
pointer asked
I want to extend Pylontech 2000 Batterie to 500 Ah
Hello Team,
I have Installed 3 Phase Multiplus II System with and everything is working fine.
I using 6 x Pylontech 2000 it s working fine. But now i want to add another 4 x Pylontech 2000.
I have 300 Ah thats + 200 Ah I write the new number into the multiplus ok.
How do i make the bus connection and the jumper adjustment?
since the cerbogx does not recognize the pylontech 2000 with the recommended adjustments from the pylontech 2000 manual.
Multiplus-IIbattery chargingbattery
lifeingalicia avatar image
lifeingalicia answered ·
pointer answered ·
essentially it says i have 10 Pylontech US2000 Batteries and can only use 8 or i need to get the LV hub?
As far as I know yes you should use a hub.
Probably also advisable regarding any waranty issues...
1 Bit addressing so just 8 on one can bus.
You could generate two banks with two can bus cables but can only see one in VRM
klandos avatar image
klandos answered ·
At least with the “c” type pylontechs 16 modules are possible without LV Hub.
