sanchuka avatar image
sanchuka asked
Pylontech US3000 Upgrade (Should change BMS Type Cable?)
I'm offgrid user and today added 2 pylontech us3000c to my existing us3000b. Since us3000c is now master battery i read that should be use victron bms type a cable. Since i have previous victron bms type b cable i connected with it and is working (5 modules recognized). I'm planning to change it when i travel near a victron dealer as per documents recommendation, but is unsafe using like this meanwhile? what is the function of pin "gnd" where i notice is the cable difference?
Thanks, attached some pictures. (balancing cells before connect to cerbo. cerbo gx information after connecting) winter time patagonia-southamerica.
cerbo gxBMSPylontech
sanchuka answered ·
@Ned Yu (Pylontech) May you help me please with your advice and technical comments, Thank you! Regards!
ponzoa avatar image
ponzoa answered ·
In theory yes, you need to change your cable. I would change it, even if it is reading info from the battery as it's a low cost item.
sanchuka avatar image sanchuka commented ·
yes, as soon arrives to city new cable type A i will change it. Meanwhile i hope not to be unsafe using it like mentioned above (cable type B). thank you!
Hi @Sanchuka,
I think you are doing everything correctly, get that cable changed as soon as possible.
My limited understanding is that your current configuration opens the possibility for a potential differential which could in some circumstances lead to communications issues, and potentially damage to the communications chips, as there might be an earth/ground differential. This is not a certainty, not even very likely and would indicate some other issue with the system, so it's not an urgent situation - but definitely one you want have resolved long term.
If the extra capacity for the system is not important, I would leave the extra battery shut down and disconnected until the correct cable can be installed.
If the extra capacity for the system IS important, then I would continue as you have it, operational, and then replace the cable as soon as you can.
Thanks for the explanation. I will change it next weeks when i go physically to the installation. Right now is just a router and couple of wifi cameras as consumption (little cottage), so far no issues. Glad to have Victron support. Regards!
