danirpg avatar image
danirpg asked
VE.Direct HEX protocol on Phoenix Smart IP43
Hi. I see this question before but no one responded.
I need the HEX protocol of this charger for a proyect i have.
Thanks.
@mvader (Victron Energy)
@Guy Stewart (Victron Community Manager)
VE.Directcommunication protocolprotocol
@danirpg moved to modifications
Mike Dorsett avatar image
Mike Dorsett answered ·
Try setting up a program to read the hex registers using the default protocol and comparing the results with either the asci stream or victron connect. I tried this for the smart shunt, with fair results for reading the registers.
danirpg avatar image danirpg commented ·
Its a good idea!
I see the in one post the SmartShunt uses the same registers as BMV7XX with some capabilities of course.
Maybe i can follow the HEX documentation for MPPT Chargers and apply to this charger?
Im gonna try it. Thanks for the idea!
danirpg answered ·
I tried to read the values following the HEX protocol for MPTT and it works!
Also i tried some registers from the BMV HEX protocol like the main voltage monitor (0xED8D) and works also!
So i guess the register are common between products and they implement depending on the product
Thanks for the idea @Mike Dorsett!
johanndo avatar image
johanndo answered ·
The VE.Direct hex protocols are published on the Victron download area, you have to submit your e-mail address to get the download link.
Mike Dorsett avatar image Mike Dorsett commented ·
I tried looking there for the smart shunt protocol, and it was not there at that time.
johanndo answered ·
I think, there are 2 files, one is for the BMV and the other has all other Ve.Direct devices covered, just read through the files. Smartshunt and BMV are the same.
