Danakil avatar image
Danakil asked
Ve.Direct Protocol: Device state register
Hi everyone,
I am setting up the communication between some SmartSolars 250/100 and an embedded system to control them using Ve.Direct protocol.
I mostly use the "Remote control Register" (0x200i) for that and everything is fine except for the "0x200C : Device State" which just timeout me...
I also tried the old way, using 0x0201 but same result. All the SM250/100 are up to date with the 1.59 version.
Is it because the BMS mode is activated ? Or any idea of what's going on ?
BTW I think there is an error in the documentation, to activate the BMS mode, we need to set 0x200E to b0001000 instead of b0001001. The Networked bit 0 doesn't seem to work properly.
Thanks
Best regards,
Nicolas
VE.Directcommunication protocol
Mike Dorsett avatar image
Mike Dorsett answered ·
I think the device state register is inactive in the BMS mode, but you should get a value back, not a timeout.
Danakil answered ·
Hi Mike,
Thank you for your answer, reading your post made me check my code and I realize I forgot a statement, that's why there was a problem... :/
VE.Direct protocol FAQ
