snakesteve avatar image
snakesteve asked
Cannot connect to VRM Portal
Hello, About one day ago my Cerbo GX stopped communicating with the VRM Portal. I have reset the system, verified it is connected to the wifi hotspot, and it still does not connect. All else seems to be functioning nominally. I have included some screenshots of what I am seeing. Any ideas on how I should proceed to get things back online will be much appreciated.
All the communications errors listed below up until the most recent on 6.30.22 - were from driving through areas without cellular coverage. The error on 6.30 at 5:46 was the start of this problem but the RV was parked in my driveway and I was asleep when this error occurred so I have zero ideas on what has caused it.
cerbo gxVRMconnection issue
snakesteve answered ·
UPDATE: I solved the problem. It was in fact the wifi hotspot. It's connection to the cellular service had become intermittent and was therefore preventing the Cerbo from connecting to the Portal.
