schweizp avatar image
schweizp asked
VRM-portal: missmatch PV-power / battery / power / consumed power
As can be seen on the attached screenshot the dashboard shows illogical values.
  • The PV-power is verified and correct (power meter).
  • The battery power is verified and correct (BMS).
  • The grid power values are verified and correct (grid meter).
  • The values on the critical load tab are absolutely not correct.This same behavoiur can be observed every day. Sometimes during the day it suddenly shows the correct values. Up to now I could not find any reasons for when the values are correct/incorrect.
Any ideas? If this was already discussed and is a known topic I would be grateful for a link. I was not able to find anything...dashboard-screenshot.png
VRMdashboard display
