sweyn avatar image
sweyn asked
Main battery switch before Lynx distribution system?
I notice in the various Victron produced circuit diagrams for the Lynx system, they never put a main system switch before the Lynx distribution system/Lynx Smart BMS, however most actual people building seem to fit a physical switch between the battery and the Lynx.
Is there a reason why I should fit a physical switch?
I’m assuming people don’t like relying on the software controlled contactor In the Lynx Smart BMS?
Is this just aversion to change, or is there a good reason such as a regulatory requirment?79400d65-8b4c-4b88-a223-1ff2d0ad20b4.png
lynx distributorswitchvirtual switch
Hi @Sweyn again,
The Lynx Smart BMS has a remote on/off port to which you can connect a simple physical switch (as opposed to a soft switch via VictronConnect or a GX device) and then use it as the main system switch. The only drawback is that it still draws power, albeit at a negligible rate of about 0.50 mA.
If you don't want that, or want to isolate the batteries from the rest of the system, then use a system main switch on the battery side (note the current rating). That's how I did it in one of my systems.
sweyn avatar image
sweyn answered ·
Thank you Stefanie, again very helpful!
