jasoncodispoti avatar image
jasoncodispoti asked
Connecting Phoenix VE 1200 inverter to outlet?
I am looking at adding power to a small teardrop camper via two 100 amp hour 12v LifePO4 batteries. The Victron Phoenix Inverter VE Direct 1200 would be perfect for my needs. However it only outputs to a GFCI plug. So my question is could I hard wire this inverter into my campers electrical setup (outlets) using an electrical cable with a plug on one end only? Alternatively I could just run an electric cord from the inverter to the shore power port on the camper, but this would not be as ‘clean’ or easy to use as hard wiring.
Note I do I understand that backfeeding needs to be avoided if connecting the inverter and shore power at the same time.
Phoenix Invertercampervan
Phoenix Inverter product page
Phoenix Inverter Smart product page
