I have two of them for my work laptops, I cannot have them on the same circuit otherwise they will drop a 16A circuit breaker when switched on.
Victron, for all intents and purposes, has no Customer Support, and this useless forum is certainly no substitute.
Going back to your Previous Question , where have you wired the inverter to?
14awg is to thin.
As a test, wire the inverter directly to the battery using the recommended gauge cable. Be careful, dont short things out or reverse connect the inverter.
I'm hoping!
26 People are following this question.
