stokie77 avatar image
stokie77 asked
Why is my Victron Easy Solar unit only drawing half of the usual generator power?
For some reason my Easy Solar (with 48V Lithium BYD Box) is only drawing about half of the power it usually does when the generator is running. The battery temp doesn't seem to affect it, whether 14 deg C or 20 deg C.
I tested the generator supply out by switching on my coffee machine while watching the monitor - Generator Watts jumped up from around 800 W to over 2000 W. Then straight back to around 800 W when I switched the load off. In Console I tried adjusting the max charging amps up and down, but the actual charging amps are still well below this setting.
The generator usually cruises along at about 1450 Watts of charge. Why would it have suddenly dropped to 800W ?
battery chargingGeneratorEasySolar All-in-Onecharge current limit
