Tomas avatar image
Tomas asked
Restrat when battery is fully charged with grid without grid feed-in
Hello. I have problem with this. (three phase) Configuration is 3x Multiplus II 3000W 48V, GX modul, 1x MPPT regultor 150V/85 and 1x MPPT regulator 150/70, 1x VictronSMARTHUNT 500A with 16x lifepo4 battery 300Ah. BMS is JIKONG B2A24S150 and current senzor. With ESS configure. When battery is fully charged and connect with GRID system fall down and multiplus II is restart When enegry is in FV panels. I disabled feed-in is disabled. Grid metering is "Inverter/Chrarger" If I use off-grid everything is corect don´t resatart. Have you ever solved this problem.
Lithium Batterygridmultiplus in parallel
