I'm considering buying a Phoenix VE Direct Inverter to load test individual batteries . Do you get the input current and voltage ( DC ) values on the VRM once connected via Venus GX? Just need to know before I buy the unit?
Hi Merle,
I would not recommend this application. The current sensor readings on the VE.Direct inverters is not accurate enough for testing.
A BMV-700 connected to a VGX would be far better.
Will not work - have 2 banks of 4x 12V batteries 48V system - need to test each 12 V separately
I want to test each 12V battery separately ( have 48V MP ) in a repeatable way in order to compare discharge characteristics with each other and published manufactures curves
I can understand that accuracy may not be great but do you think its consistent / repeatable?. Can use multimeter to do spot reading checks
6 People are following this question.
VRM Portal ID Location? 2 Answers
Changing Venus Device in VRM needs confirmation? 4 Answers
*** INFO ONLY *** How to use ve configure 3 to Remote update Multiplus and Quattro Units via VRM 4 Answers
Looking for iOS App beta testers 5 Answers
MultiPlus and Phoenix VE.Direct connected to Venus GX at the same time? 1 Answer
