R avatar image
R asked
BlueSolar PWM-DUO LCD-USB - Two Different Ah Banks
Currently have 2 of the BlueSolar PWM-DUOs rigged up in parrallel, so each one has a connection to battery bank 1 output and battery bank 2 output.
Is it acceptable for bank 1 and 2 to have different Ah capacities?
Specifically 10Ah 24V on one and 32Ah 24V on the other.
battery chargingLithium BatterybatteryBlueSolar PWMbattery connection
kevgermany avatar image
kevgermany answered ·
Not ideal. Whichever battery finishes charging first will be maintained at absorption voltage until the second also finishes charging. This will lead to a shorter service life. If you reduce the absorption voltage settings to the minimum for those batteries, you'll have less life reduction.
Battery Compatibility
VictronConnect VE.Bus charging manual
