tmm avatar image
tmm asked
Sonnenschein PRO Series & Multiplus-II compatibility
Hi Team Victron, can you please advise on the compatibility of Sonnenschein PRO Series with Multiplus-II (48V system) or are there any documents stating the same ? The Sonnenschein datasheet shows Victron-compatible however the Victron list does not include Sonnenschein PRO Series.
Secondly, I'm currently planning to use 1xMultiplus-II/3kVA, 4xSmartSolar 150/35 (1.5kWp Solar per controller), 4xSonnenschein PRO Series 9.6kWh in a 48V system. Communication-wise: Colour Control GX with Victron 4G Modem & GPS for GX Controllers. Would you have any concerns about the configuration?
Multiplus-IILithium Batterysmart solar charging behaviourcharge controller compatibility
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Battery Compatibility
