I have invertor Victron Phoenix Compact 12/800. Now I bought a new EasySolar 12v. Could I install them in parallel? I cannot find the solution.
No, this is not possible. For parallel connection both devices have to be identical.
No, as per the Parallel, split- and threes phase VE.Bus systems guide all units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number.
35 People are following this question.
