rob-glazier avatar image
rob-glazier asked
Wiring Options for Blue Smart Charger 12|
Hi All.
I recently purchased the Blue Smart Charger 12 | 7 and I'm wondering if it is suitable for my use (I suppose i should have asked this before buying it). I have a 26' sail boat with a single 12V AGM battery, and currently only a DC system. All loads are very light, under 2amp draw.
I'm wondering if this charger is suitable to be installed for charging on an ongoing basis when hooked up to shore power? and also the charger comes with a 3 prong AC plug for input, can this plug be stripped and wired into an AC panel as i've planned in my wiring diagram?
battery chargingchargerwiringwiring diagram
kevgermany avatar image
kevgermany answered ·
Should work, but you may need galvanic isolation. Best check.
rob-glazier avatar image rob-glazier commented ·
Thanks for the response. The boat is in fresh water and has an outboard, so i'm on the fence on the isolator
Victron Wiring Unlimited PDF
Victron Wiring Unlimited Online
VictronConnect VE.Bus charging manual
