never mind
The GX Touch is just a touchscreen display you also need a Cerbo GX.
The Cerbo GX should be placed near the place where the CCGX is to connect all cables from the CCGX to the Cerbo.
I assume you know you would also need a Cerbo, the GX Touch doesn't connect to the CCGX sadly.
I think you would need to feed a long HDMI / USB cable.
Thread discussion here on extending the cable: https://community.victronenergy.com/questions/47070/cerbo-gx-to-gx-touch-50-extender.html
Matthias beat me to it, but also I have a CCGX and an old 7" android tablet mirroring over wifi in a different location to the CCGX if that's the main thing you want?
I followed this thread: https://community.victronenergy.com/articles/5930/disable-hotkeys-in-venus-remote-console-on-lan.html
Then you could also run Kevin's GUI Mods on the CCGX while you're at it, https://community.victronenergy.com/idea/77971/venus-os-modification-scripts.html
but it was a steep learning curve for me to get it all running on the tablet, but saved me having to swap out the CCGX for now.. :)
all the cables from the CCGX just plug into the CERBO GX the touch 50 display comes with its own HDMI cable that also plugs into the Cerbo - there should be NO extra cables needed.
the cerbo also gives you a extra USB and VE direct port
plus you can monitor 4 tanks
Plus 4 Digital inputs
Plus 2 external relays that you can control from the GX Touch screen
Plus many more advances
47 People are following this question.
