tsawind avatar image
tsawind asked
MultiPlus 24/3000/70 "Stop charger below" Temperature
I have a MultiPlus 24/3000/70 With a 24v 600aH LiFePO4 bank. These batteries do not have low temperature shutoff. I Have the temperature probe extended and giving accurate reading at the batteries. I have the MK3-USB and VE Configure 3 loaded. Under the "Charger" tab, there is no "Stop charger below" (insert temperature). This checkbox is available when using other models, like a Quattro, I really need this setting for this system!
Extremely frustrating, I do not want to destroy thousands of dollars worth of batteries because this multiplus won't stop charging when a heater malfunctions.
Thank you for your time and solutions.
BMSVEConfigure 3Temperature Sensortemperature
Hi and welcome to community!
What firmware version is that Multi updated to? Make sure its the latest.
Also make sure to have the most recent VEConfigure or VictronConnect.
The setting will be available with both parts updatedz
Matthijs
Victron temperature sensor disambiguation table - which product supports which sensor
VEConfigure manual
VEConfig alternative method for VE.Bus using VictronConnect
