marv2097 avatar image
marv2097 asked
Incorrect voltage reading on DC-DC Charger
I have an Orion 12|24-15 Non Iso DC-DC charger. Its input is a 12v starter battery on a Sprinter and the output is a 24v Li-Ion pack and they share a common ground.
I have been seeing strange charging issues and over-voltage alarms. On closer inspection the voltage shown in the app for the Orion doesn't match what I measure at its terminals with a meter.
These 2 images show the exact same time but a difference of 0.35v. Its been worse than this on other occasions and reads both under and over randomly.
Has anyone seen this kind of issue before on a DC/DC? Its on the latest FW, could it be a fault in the unit or my setup?
Additional Info
All Bluetooth devices have the latest firmware available in the Victron App.
As I am measuring at the terminals I dont expect cable or connector losses to be an issue here. I also have a good bit of other Victron kit on the same 24v side which all agree with the multi-meter consistently under < .1v difference . All the kit is connected on the 24v Side via a Lynx distribution unit with cable well within its ratings. Connection tightness double checked. As mentioned earlier sometimes the voltage in the DC-DC app reads over sometimes under and it seems to move around day to day.
Heres a comparison of readings:
Device Reported Voltage
Orion 12|24 - 15 (Output) 24.2
MPPT Smart Solar 23.88
Orion 24|12 - 30 (Input) 23.9
Smart Shunt 23.85
Multimeter 23.85
Any advice or questions welcome. Many Thanks!
Martin.
battery chargingOrion DC-DC Converters not smartvoltagecampervan
melgamal avatar image
melgamal answered ·
I'm having the same issue, the output is showing exactly like you 24.2V however the output is 21.6!! It's stuck in absorbtion charge. The other orion charger is working as normal.
melgamal answered ·
Figured it out. in my case it was an open circuit due to a loose connection
Victron DC-DC converters product page
