According to the Data Sheet and the manual a synchronised Parallel Operation with up to 25 devices connected via VE.Can is possible.
Is a 3 Phase system Setup also possible ?
Hi, the Inverter RS can synchronise its (solar) charging.
but not its AC output. Not for parallel operation of the inverters, and not for three phase or split phase either
Some day it will, but not now.
29 People are following this question.
How to connect GX cerbo with Multi Rs Solar MPPT 450
Can SmartSolar MPPT RS 450|100 & Inverter RS Smart Solar 48/6000 operate on the same VE.CAN Network?
Victron Quattro 10KW delivering only half rated power
ET340 energy meter AC loads disappear and exporting to grid
15Kw 3 Phase VFD pump - how many Kva of Victron Inverters will it take to run this?
