athlonfx avatar image
athlonfx asked
Multiplus II GX ESS Pylontech US2000 seems running fine, should I upgrade firmware?
Hello everybody,
I recently got a Multiplus-II GX installed, combined with 2 Pylontech US2000 (new) and an EM24. It's configured as a grid tied ESS system. There's also a grid tied PV micro inverter (Hoymiles). Everything seems to work out fine, as far as I can tell. The Multiplus II GX detected both the batteries and the meter, charging and discharging seems to work as expected. The installed firmware version is 2.60.
Should I update the firmware to the latest version (2.73)? The ESS manual says it should be done with the installation - which wasn't.
If I update the firmware via the remote console (LAN), will the settings be reset as mentioned in the manual of the Multiplus-II GX?
Multiplus-IIfirmware updatePylontechem24
Paul B avatar image
Paul B answered ·
yes - that update for the GX device should be fine - BUT any software update can cause changes you dont like - so maybe use this advice- if its not broken then dont update.
only update if you are after new features or you want to fix a issue - is always good policy.
with the gx device you can always roll back to the older fw it needed so its not that big a deal.
nickdb avatar image nickdb ♦ commented ·
If you intend using VRM/VC for reporting and remote work then remaining current with the GX code is a good idea since they are all inter-related.
