I have a pylontech battery and the Multiplus 2.
I want the multiplus to switch to mains at a certain battery level, e.g. at 10% battery level.
However, the multiplus goes down when reaching about 12%.
If I set the threshold to about 13%, it usually works without problems, and only occasionally (once a month) does it go completely down.
I will try to raise the threshold to 15% to solve the problem.
However, I am interested, why the Multiplus ever goes down, if he should simply switch to mains operation?
Sends the Pylontech battery possibly a shutdown signal, because if I remove the CAN bus Cabel from the battery, the Multiplus does not go down?
Thanks in advance!
Thanks in advance!
