colins avatar image
colins asked
Venus GX (Cerbo) configuration - import/Upload to multiple system production line!
We have a contract to build a large number of off-grid systems (all Victron products) rolling out well in excess of 100 systems over the next few months. The systems are identical. We use VE.Config to set up the Multis but the Cerbo setup has to be done manually via a T50. It's slow and tedious with various parameters/settings needing input into each system. Is there a way or could there be a way to upload a Venus OS config to the Cerbo to speed up the process? (how about an OS.Config/OS.Config Remote via VRM App!). @mvader (Victron Energy)
cerbo gxVenus OSVEConfigure 3
Paul B avatar image Paul B commented ·
a few weeks ago on 2.80~20 or about there victron had a back and restore feature available for the cerbo . however its been removed as there some issues with it, but this would have worked well, maybe look through the change loggs for the beta firmware and fine the version. then maybe you can get the firmware to work with to do all the updates
