binderth avatar image
binderth asked
Raspberry pi 2B+ loses Wifi connection / USB Wifi dongle
I'm using Venus OS 2.73 on a Raspberry Pi 2B+ with a Wifi dongle.
Wifi works fine, but after a while Venus OS goes offline and shows "error" on the Wifi, and I have to manually reboot the Pi. I know, there's a "power saving" mode in Raspberry Pi regarding Wifi and normally I would add to my /etc/network/interfaces
wireless-power off
But from what I see inside that file, connman is used for Internet connectivity, which I don't know and I didn't find powersaving options in connman man-pages...
Is there some way I can deactivate power saving - or do something on my Pi losing Wifi? (the router is right next to the Pi, so signal is strong enough.
strangely enough, power_save seems to be off anyways:
root@venus:~# iw wlan0 get power_save
Power save: off
Raspberry Pierrorwifi
aph avatar image
aph answered ·
Hi binderth, I seem to have the exact same problem, once every 24 hours wifi stops working and can only be restarted by reboot.
did you find a solution to this?
CU >>> Arne <<<
chuckenglehart avatar image
chuckenglehart answered ·
I am seeing the same issue with an older Netgear USB WiFi dongle with VenusOS v2.92 on a Pi 2B. 5v/2A power supply. I have tried this dongle on other non-pi machines and haven't seen an issue.
From lsusb:
Bus 001 Device 006: ID 0846:6a00 NetGear, Inc. WG111v2 54 Mbps Wireless [RealTek RTL8187L]
So far I am in the same spot, tried the same commands.
For the next few days I am just going to try having a cron job reboot the pi every 4 hours to see how that works.
chuckenglehart avatar image chuckenglehart commented ·
I got rid of my cronjob, and clicked the option to reboot after no network activity, and set the threshold to 3 minutes.
While this isn't a fix, it has been a good workaround.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
