Hello all
VE Bus State for Multiplus ok on VRM dasboard but not in VRM advanced
The correct state is Absortion as showing in dashboard but the state is OFF in the advanced view
Hello all
I have a similar problem. The VRM has the correct data, it looks like an issue with the graph times. I get the correct VE bus graphs on 24 hours and above, but incorrect on 12 hours and below. See enclosed
Three hour
24 Hour
The data on the left shows it is in absorption, but the 3 hour graph shows bulk.
This is with a Multiplus and latest software @victron
Thank you for reporting this. The issue should be fixed now.
36 People are following this question.
