bram1 avatar image
bram1 asked
Camper electric; combining Multiplus Mppt and Orion smart DC-DC
Campervan electrics
I am currently rebuilding a Fiat Ducato van into a campervan. For the electrical system we want to use a 230v fridge, a roof fan, Led lights and some smaller accesoires such as usb chargers etc.
A rough estimate of powerusage:
Watt
Hours p/d
Wh
Ah @12v
Fridge 230v
20
24
480
40,0
Usb
14
1,4
19,6
1,6
Lights
20
3
60
5,0
Fan
35
6
210
17,5
Laptop/bikechargers etc.
90
1
90
7,5
Waterpump
100
0,5
50
4,2
Total
909,6 Wh
75 Ah
Adding losses, I estimate a bit less than 100Ah/day.
Charging
  • Multiplus 800VA
  • Orion DC/DC smart 18A or 30A
  • Mppt 75/15 with +- 200Wp solar
Storage
The intended use of the camper van is to travel around, stay a day or to and then move again. so alternator charging and solar should be most of the charging required. Going with a multiplus is a nice to have, as adding a charger later would require a lot of components if I buy a separate inverter.
I am still looking into what I can afford,100Ah lithium sounds great, but 220Ah AGM is also reasonable for our uses. Due to a smart alternator a DC/DC charger seems needed anyways, so all should be easily set up for both chemistries. We’d prefer using a 12v system, as this is commonly used.
Do you have any remarks on this schematic?
(Apart from the not displayed safety on the 230v AC, and the non-calculated wire gauge.)
My question;
Can I combine the Multiplus, orion smart and mppt without a shunt or GX device or is this not advisable? As far as I can tell this is mostly for monitoring?
The multi and orion won't interfere with the ignition switch used, so it is mainly the communication between the MPPT and other chargers that could be problematic?
Thanks in advance!
Bram
MPPT SmartSolarorion-tr smartmultiplus ve.bussolarschematics
The system will work without a BMV/SmartShunt/GX device but I would recommend at least a BMV or SmartShunt monitor the SOC.
savage-mechanic avatar image
savage-mechanic answered ·
Hi there,
This is a very simular to a setup i would like to do with my motorhome with the edition of a smart shunt or BMV.
my question would be, Can the MPPT and the Multi plus communicate when there is good sunlight and mains power available?
Kevin Windrem avatar image
Kevin Windrem answered ·
Definitely add a BMV or smart shunt.
I'd also recommend Cerbo and a GX Touch 50/70. Some less expensive HDMI touchscreens would work with Cerbo if you can't afford the GX Touch. Cerbo is the piece that improves interplay between devices and centralized control.
You might want to consider a DC refrigerator. Running on 230 volts will require the Muilt to run 24/7 which is an additional 6 watts or 12 amp-hours.
If your expected load is near 100 AH, I'd plan 200 AH of USABLE energy. The AGM should only be drained to 50% so that's not much help
