ktillman79 avatar image
ktillman79 asked
Mppt 100/20. Not registering solar.
I'm trying connect my 260ah AGM battery and 320w solar panel to my mppt 100/20. It registers the battery but I have 0w and 0v from the solar. I've triple checked the wires are connected properly and the right way round. I've checked the fuse and I've checked the wiring using a multi meter and there is power coming from the panel but the controller still isn't recognising it.
I'm aware it needs +5v above battery voltage to charge but I'd have through midday on a sunny day it would produce that easily.
What am I doing wrong? Anyone got any thing else I can try?
Thanks in advance.
MPPT Controllersbattery chargingMPPT SmartSolarsolar
launacorp avatar image
launacorp answered ·
So you checked the PV wires with a Multimeter disconnected from the MPPT? Whats the Voltage then?
If u then connect the pv wires to the terminals an measure the voltage then with the Multimeter in the terminals, what's the voltage then?
astrungis avatar image
astrungis answered ·
Me too! I bought a 2021 Coachmen Sportscoach. I believe Jaboni set up the solar system (100W s. panel on the roof and charge controller in the basement near the batteries). Question: Why isn't the solar panel registering on the charge controller? I took the two + - leads off the controller and receive 19.2 V on my multimeter. Yet when connected, it doesn't show the solar and thus not charging the house batteries.
rfj avatar image rfj commented ·
same here what? I have to constantly reset the controller with 30 amp circiut breaker swiches installed separate ones to battey out & solar panel input. I got it to work by redoing the wire connections even though they were right. I only got it to float once! They now work for a couple days then shut down again. Shows proper battey voltage & no current.
any thoughts here , frustrating.
thks
kevgermany avatar image kevgermany ♦♦ rfj commented ·
Please get your dealer to check the unit
Victron PWM 10A Solar charge controller
