goon326 avatar image
goon326 asked
Cable sizing of multiplus 12/1600/70 compact
Dear users,
Again a question from me, I think I settled for the following setup:
- Multiplus 12/1600/70 with temperature sensor for battery
- BMV-712 smart with bluetooth
- 75 - 15 MPPT with bluetooth (300W solar panels)
- Orion TR DC-DC 12-12/30 with bluetooth
- 200ah lithium battery with 200A BMS (not from victron)
- Cerbo GX S
My question: Are the 35 mm2 cables connected to (and provided with) the multiplus 12/1600/70 sufficient for the full capacity for the DC/AC converter and the peak capacity of the multiplus?
I am going to use my multiplus for charging and for my 1000W airfryer, most of the time it will be used once a day for 15-30 minutes.
Kind regards,
goon326
BMV Battery MonitorMPPT SmartSolarVictronConnectorion-tr smartmultiplus ve.bus
cardy01 avatar image
cardy01 answered ·
The manual says to use 50mm2 ......
goon326 avatar image goon326 commented ·
Why do they provide 35 mm2 with the product? That is weird right?
cardy01 answered ·
I have a 12 1200 50 which needs 35mm2
You might want to look at the discharge rates of your batteries - your air fryer will pull around 90A on the DC side whilst running - I don't have lithium just AGM GEL but my batteries wouldn't support 90A for 15 minutes.
This link helped me https://community.victronenergy.com/questions/4454/peak-power-of-victron-inverters.html
