sales-1 avatar image
sales-1 asked
Double Consumption on VRM
The VRM is showing double the amount of consumption.
The System comprises of the following
  • 2x - MultiPlus II 48/5000 - Running in Parallel
  • 2x - Smart Solar 250/100
  • BMV
  • Venus
  • 3x - DC-DC 48/24 - For Lighting
The issues that that I have and is best seen between the hrs of Midnight and 6am when the only loads are static. Which you can see on the VRM History. This data adds up individually, but in the System Overview on the Dashboard, the Total Consumption is Doubled.
I’ll try and describe as best as possible below
  1. AC Consumption Doubling/Incorrect Readings
    1. On VRM History between Hrs of 00:00 and 06:00 system shows consumption averaging about 370watts per hour – However –
    2. On VRM Dashboard VRM Consumption showing average of 740watts per hour??
    3. Screen Shots Below of “a” & “b”
Multiplus-IIMultiPlus Quattro Inverter ChargerVRMmultiplus in parallel
