mstr avatar image
mstr asked
Remote control on/off Orion DC-DC isolated by using Color control GX
I would like to control my Orion DC-DC on/off remote by using the CCGX (color control GX).
Goal is to remote control on/off when needed and automatic on/off based on battery voltage setpoint low/high. (disconnect when battery low and reconnect when battery charged and ready.)
I understand it should be possible to use the relay on the CCGX, but I can't find a good description how to do it.
Anyone have experience and could guide me?
CCGX Color Controlorion-tr smartremote console
JohnC avatar image
JohnC answered ·
Hi @mstr
You could probably do this with the generator function.. https://www.victronenergy.com/media/pg/CCGX/en/gx---generator-auto-start-stop.html
I use an assistant in a Multiplus to switch my Orion, and it works well. Don't even remember why I chose that before my CCGX, but both ways should be ok.
mstr avatar image mstr commented ·
ok and thanks
What about the wiring between the orion and multiplus?
JohnC avatar image JohnC ♦ mstr commented ·
@mstr
You have a Multi? I just ran a single thin wire pair, as I would have too for the CCGX.
I think I may have chose the Multi because I wasn't sure if the relay function was reversible in the CCGX. Ask if you need help with the Multi.
