rmaddy avatar image
rmaddy asked
Is it safe to turn off a MultiPlus under load via VRM?
I have a MultiPlus 24/2000/50 connected to a VenusOS device which allows me to connect to it via VRM.
About the only thing I will be using with the inverter is a small air conditioner that uses 420W while the compressor is on.
Is it safe to connect to VRM and tell it to turn off my inverter while the A/C is running? This is just incase I end up being away from the trailer unexpectedly for a few hours and realize I left the A/C on.
MultiPlus Quattro Inverter ChargerVRM
Kevin Windrem avatar image
Kevin Windrem answered ·
Should be fine. The shutdowns appear to be very clean even under heavy load.
Just wait about 5 minutes to turn it back on to avoid the huge power spike when the compressor tries to start while there's still pressure in the tubes.
rmaddy avatar image rmaddy commented ·
Thanks. I will rarely need to do this but hopefully it's fine if the need arises.
