gregarious avatar image
gregarious asked
Most Cost-effective Way to Add VRM Functionality
A have the system described below on my motorhome and wanted to add VRM functionality. What is the most cost effective way to that and would that part supplement or replace any part below? I already have a data modem that services the coach that is almost always on. Thanks.
- BMV-712 Smart Battery Monitor
- 6 x 200-watt solar panels
- 5 x 200 AH Victron Lithium Batteries
- Multiplus Inverter/Charger 12V / 3000VA / 120amp
- VE.bus BMS
- VE.Bus BMS Mains Dectector
- SmartSolar Charge Controller MPPT 150/100
- Tr VE.Can
- Skylla-i Control GX
VRMremote console
A Cerbo GX would be the easiest way, every thing would be plug and play.
(you need some communication cables for VE.Bus, VE.Can and VE.direct)
The cheapest would be a raspberry Pi, but you have to install Venus OS. To connect VE.Bus you need a MK3 interface. I'm not sure how to connect VE.Can. For VE.direct you need a VE.direct to USB interface.
