I have this weird outlier in the middle of the night which is obviously wrong since i have no sun and then direct use of that in the middle of the night.
Is there a way to remove this and fix this bug from not happening again ?
Hi @peternielsen,
These spurious solar production reporting issues are most commonly associated with AC PV inverters.
I haven't seen one for quite a while, and as far as I am aware, they have all stopped in systems once it has been confirmed that GX device firmware, Datamanager card firmware, and AC PV inverter firmware are the latest current versions, AND that the unit networking is hardwired with a manufactured ethernet cable from the AC PV inverter, and the GX device (no wifi).
Please also make sure there is sufficient clearance (10cm) between any data cables, and power cables (either AC or DC).
Please double check to make sure all of those are the case, and if they are, and it is still occurring please report back.
I can say with certainty that this is not an issue with VRM as such, VRM is faithfully displaying the data that was reported to it, and the erroneous data most likely occurred between the AC PV inverter and the GX device.
I believe the Fronius PV inverter is updated to latest 1 week ago, not sure if i can update the Datamanager card inside it separetly ? The Fronius is wired with ethernet BUT the Cerbo GX is WiFi so here i have a task to disable the WiFi and use Ethernet. This issue only happened once. Is there a way to remove that data now or do i just have to live with it ?
Funny enough if i take the total yield from the Fronius (looking at the GX device) and the total yield from the SmartSolar i get the correct value without that spurios solar production. If it came from Fronius shouldn't this sporius data also be included in the GX?
Yes, the Fronius AC PV inverter firmware, and the data manager are updated separately, some more info here:
SE_TEA_Quick_guide_How_to_update_Fronius_Datamanager_firmware_EN_AU.pdf
https://www.youtube.com/watch?v=FwuakhLZ10A
I don't have access to the VRM database, apologies, but I think you might have to have that bad entry.
Good Day Guy. We are experiencing the same issue, no PV inverters installed, only 2 x MPPT 250|100 charge controllers. Both MPPT has been wired with Victron direct cables and setup for network comms via Bluetooth. All firmware is the latest firmware as well as the octo gx with the latest firmware.
27 People are following this question.
