CristiMV avatar image
CristiMV asked
VRM shows double the grid power after ET340 installation
8764-vrm1.jpgHi Yesterday I've managed to replace my main electrical panel of the house. I have a 3 phase grid, but I'm powering the house with only one phase (in the new panel, I have installed also a phase selector). Still, ET340 is installed to measure all 3 phases between the grid and the phase selector. The connection to Color GX was done via Victron RS485 interface. The ET340 is visible on ColorGX, is showing all the phases connected (yes, the L2 is done since long time), counting the power (the left led is turning green/red) The only question I have: is it normal that on VRM portal the consumption to be shown as: 2 times the grid + pv inverter? See some pictures below
VRMEnergy Meter
Hi @Cristian Miclea
You have to connect your Victron inverter to L1 (or rewire grid meter / change phase selecter to L1)
CristiMV answered ·
After some additional reading, I could understand that this behavior is normal. Any configuration I could do to not count AC Loads anymore, and only Critical Loads?
CristiMV answered ·
Hi Daniel and thanks for your answer. I’ve forced the phase selector to output L1, and indeed this solved it. This means that regardless of the phase used, the Multi is always “assuming” its on L1. Which this should be normal, as it is a single phase inverter. Still would be nice to ignore this from the logic. Anyhow, many thanks again for the feedback. Stay safe
mirko-iog avatar image
mirko-iog answered ·
We have the same problem, but with a 3-phase Fronius Symo with three Quattro 10000 and Gavazzi ET340. The CCGX also shows the double load - just like in the original post.
Additional we have the question, how the Gavazzi can be shown in VRM. They show up in the device list, but not in the advanced section.
Energy Meter Selection Guide
