I try Uploading GX files for 4 sites, 1 has been uploaded successfully ) while the remaining 3 sites had failed and attached the error message.
Hi @Abdallah Salamah Did you commission all these sites and were they all added to VRM using the same user id? Did they already exist in VRM? What has changed maybe? Are the system all running the same software versions? What maybe different? Lots of possibilities to explore unless there is a problem with VRM.
12 People are following this question.
