kire avatar image
kire asked
Bug in VRM Portal Datepicker
In Google Chrome the date picker for selecting a user defined period does not represent the selected date, but a mix of the date and format string, e.g. "jjjj.04.tt (tt.04.jjjj)" instead of "01.04.2019" or "2019-04-01".
It would also be nice if the date format could be changed depending on the language setting, e.g. in German only in the format "dd.mm.yyyy".
Browser: Google Chrome Version 80.0.3987.163
Update:
After an update of Chrome to Version 81.0.4044.92, the date fields are now empty.
VRM
I just tried it with chrome and could not reproduce the issue.
Is anyone else experiencing this?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Guy Stewart (Victron Community Manager) ♦♦ commented ·
I can confirm this Problem with Chrome 80.0.3987.163.
But after updating to 81.0.4044.92 the problem is gone.
Teun Lassche avatar image
Teun Lassche answered ·
@kire Thanks for reporting! I just released a fix for this.
kire avatar image kire commented ·
That was quick - thanks. But I would prefer "yyyy-mm-dd" or "dd.mm.yyyy" over a mix of the two ;-)
There still seems to be an initialization problem with refresh. Try to open dashboard or advanced and press Ctrl + F5. When you open the date picker, the date fields are empty and remain empty, even if you select a date.
Teun Lassche avatar image Teun Lassche ♦ kire commented ·
@kire That is now fixed as well, thanks!
