Máté Őry avatar image
Máté Őry asked
Multi remote control disabled when VE.Bus BMS configured
When the VE.Bus BMS is configured in my MultiPlus II (48/3000/35), the remote on/off/charger-only options are disabled on the gx devices (Cerbo GX). What is the technical reason for this? Is there any workaround available to put the Multi into charger only mode from the Cerbo?
Multiplus-IIBMSVE.Busgx device
bathnm avatar image
bathnm answered ·
There is no work around, and it is not clear why. If you search the forum, this has been asked a fair amount. Depending on what you need you could use a small BMS or even a Lynx Smart BMS and this limitation won’t exist.
Máté Őry avatar image Máté Őry commented ·
That's why I'm asking, I couldn't find a clear answer on this forum. There must be a reason.
