klabobidy avatar image
klabobidy asked
SmartSolar VE.Can 150/70 not temperature compensating.
Hello All,
I have a Cerbo GX connected via VE.Can to a SmartSolar MPPT 150/70 VE.Can and a Lynx Shunt 1000 VE.Can. I have DVCC enabled as well as SCS, SVS, and STS. I have found that the MPPT changes charging states correctly according to the readings from the shunt. However, it is not compensating voltage according to the temperature reading from the shunt. The MPPT seems to be compensating from the initial ambient temperature as the standalone strategy. The MPPT has v3.05 firmware and the shunt has v1.08. Any help would be appreciated.
MPPT ControllersVE.CanDVCClynx shunt
