xandafini avatar image
xandafini asked
Liontron BMS switches off when I switch on Phönix inverter
Hello to all,
I have a problem with the following combination of devices:
  • Phoenix Smart Inverter 24/3000 and
  • 2x 24V LIONTRON LiFePo 100Ah (parallel)
When I switch on the fuse of the 24 V supply from the inverter, the BMS of the Liontron batteries switches off immediately. I have found out that it is probably the capacitors of the Phoenix inverter that need too much power for the BMS of the batteries. Does anyone have a tip for me on how to solve the problem?
Is there any information on how many amps the Phoenix requires at initial start-up?
Attached is the technical data sheet of the battery.
Thank you!
Alexandros
BMSPhoenix Inverter
tozz avatar image
tozz answered ·
I see that this BMS has a Bluetooth connection. What does the BMS say about the reasons for the shutdown? Does it give any hints over the Bluetooth connection?
You are worried it's due to a high inrush current, but it could be something else. Such as under-voltage threshold?
Phoenix Inverter product page
Phoenix Inverter Smart product page
