akrolick avatar image
akrolick asked
24v Phoenix 1200w - Alternating flashing LEDs - no AC output
I've had my 24v Phoenix 1200w (120v) inverter running solidly for a little less than a year now. Firmware is 1.21.
Switched it on this afternoon and there was no AC output. The red and the green LEDs flash in an alternating fashion every half a second or so. Toolkit shows this as "Calibration or Parameter Error".
I've tried checking and resaving all the parameters (all were fine) and then refreshing the firmware with A27A_01.21 but no luck.
Does anyone have insight into why this suddenly happened or what can be done to rectify this ?
Many thanks in advance,
Alex
Phoenix Inverterfirmware update
Robert avatar image Robert commented ·
Were you able to fix it, and if so, how ? Because I have the same problem.
The current version of VictronConnect would update your firmware to V1.22 -- does that fix it?
Paul B avatar image
Paul B answered ·
Hi From your description, you should take it back to who you purchased it from for testing and possible repair or replacement
