Hello if have a new Setup with an Cebro GX and the Touch 50. I connected both with the USB/HDMI Cable but the Touch only lights up for less than a second and then it stays dark. In the VRM Device List, the Toch 50 is not listed.
The Touch 50 isn't listed as a device in the Cerbo. It's basically a simple monitor with a mouse (the touchscreen).
You could try connecting the Touch to any other HDMI output. Such as a laptop with HDMI out? If that works, you'll know it's the Touch that is at fault. If that works, probably a faulty Cerbo
Hey tozz, thanks for your answer. I tried some ohter things. So at first i took an HDMI Cable and connected the Cerbo to my TV. And at that momenti got a Picture on the TV. Then i bought a 7 inch HDMI Touchscreen at the Internet. When i connect this to the Cerbo, it says "No signal". No i realy dont know what to do!
HiThebest, it can be also that the brightness of the cerbo is 0 , so now way to see it. Connect to the cerbo / VRM and try adjusting the brightness / adaptive sensor light.
https://www.victronenergy.com/upload/documents/Cerbo_GX/GX_Device_Manual-en.pdf
Michel
I don't think you can set the brightness to 0 so the display is completely black.
I will try this later today.
Edit: I just tested it and as I thought you cannot turn the display off by setting the brightness to 0. The display just becomes darker.
@Thebest_21 I think your display is defective and you should contact your dealer to get a replacement.
Hey Mattias, thanks for your answer. I tried some ohter things. So at first i took an HDMI Cable and connected the Cerbo to my TV. And at that momenti got a Picture on the TV. Then i bought a 7 inch HDMI Touchscreen at the Internet. When i connect this to the Cerbo, it says "No signal". No i realy dont know what to do!
As I wrote above you should contact your dealer from whom you bought the Cerbo GX and GX Touch 50.
Maybe you have to send him back both devices for testing.
26 People are following this question.
