fundutzi avatar image
fundutzi asked
Venus to MultiPlus, where to set load off if battery voltage X
Dear All,
Objective: View and or change the "cut load off" if battery voltage = X volts using Venus GX connected to Multiplus.
With PC, VictronConnect software and data cable this can be set.
Devices are remote, not possible to go with PC.
Where in menu for Venus GX connected to say MultiPlus can I view and or change this setting to cut the load if battery voltage = X volts?
Thank you.
MultiPlus Quattro Inverter ChargerVictronConnectVenus GX - VGXbattery
seb71 avatar image
seb71 answered ·
You can change the inverter settings via VRM (and using VE.Configure 3 software).
fundutzi answered ·
Seb71, I am much obliged, this solved it thank you.
