aboers avatar image
aboers asked
Can a WEG Frequency drive create disturbing harmonics for a 3-Fase Quattro configuration?
For an 3 fase offgrid system with 3 Quattros - will be feeding 2 motors that are controlled by two WEG frequency drives (CFW500)
Is there any risk of that the frequency drives create a bad harmonic that can effect the Quattro inverter.
If yes, how can this be avoided?
Thank you in advance for your thoughts/solutions.
MultiPlus Quattro Inverter Chargeroffgrid3 phasefrequencydriver
