bricki avatar image
bricki asked
Skylla IP65 controlled by CAN-Bus via Cerbo GX configuration problem
Hi Community,
I have two Skylla IP65 paralleled and connected to a Cerbo GX via VE.Can and one "other" BMS for a LiFePo4 battery, also connected via BMS.Can with 500kBit/s or via the same Ve.Can bus with 250 kBit/s. Works both.
The Cerbo GX shows all three devices. Also the Cerbo shows values from the BMS for Charge Voltage Limit (CVL), Charge Current Limit (CCL) and Discharge Current Limit (DCL). I can see all three values in my BMS configuration tool also. Thumbs up!
But:
Both Skylla IP65 don't react! I tried:
- Connecting only one Skylla
- Setting Parameter #31 BMS to "Yes" - which results in an error #67 "BMS communication lost"
- Switching DVCC on and playing with some parameters
No matter what I do - the Skylla chargers do what they want instead what the BMS wants...
Does anyone have a similar configuration up and running, especially with a Skylla charger?
Thanks
Peter
cerbo gxBMSSkyllaip65
smoothfroggy avatar image
smoothfroggy answered ·
Hi Peter,
Sorry, I don't have identical setup but only a Skylla IP65 connected via VE.Can to a BMS (REC-ABMS) with the whole supervised by a GX. Same issue with the Skylla which do not follow CVL & CCL issued by the BMS though GX show CVL, CCL and DCL provided by the BMS and Skylla report properly to the GX.
Did you had any luck on that one ?
Best regards,
Xavier.
Unfortunately the ip65 is not supported for DVCC:
https://www.victronenergy.com/media/pg/Cerbo_GX/en/dvcc---distributed-voltage-and-current-control.html#UUID-137722ab-6d45-db8c-47f7-581403ef7d9a
you'll need to connect the 'allow to charge' output of BMS to the remote control input of the charger.
