siemcio avatar image
siemcio asked
Can i operate Multiplus from touch50 and cerno
Hi, can i operate Multiplus with Touch50 snd cerbogx ( inverter/off/charger and Amperage control ) or i need additionally DMC ? Or maybe is another way ? Thank you for help.
cerbo gxgx device
Hi @Siemcio,
yes you can - unless you have a VE.Bus BMS in your system.
siemcio answered ·
Thank you for answer , unfortunately I have VE.Bus BMS with Victron LifePo4 battery , so there is any other configuration with victron battery ? Can I use different BMS ?
4 comments
What MultiPlus do you have?
siemcio avatar image siemcio Matthias Lange - DE ♦ commented ·
I have MultiPlus 12/3000/120-50 120V
Matthias Lange - DE avatar image Matthias Lange - DE ♦ siemcio commented ·
With a MP 3000VA you can use two inverting remote on-off cables (ASS030550100) and install the two-wire-BMS assistant.
https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf
Thank you. If I understand correctly I have to connect one cable to Aux I/0 and secound cable in temp sense in my multiplus. Instal two signal support bms program. And thats it ?
Is this setup safe for multi and battery ? Do I loose some other function in this situation ? Thank you
siemcio answered ·
