Andrew Jefferies avatar image
Andrew Jefferies asked
Generator Warm Up, Charger walk in
Is there a way to gradually increase or limit charge current on a Multiplus / Cerbo GX to allow Generator to warm up ?
Only presenting FULL charging load when it is warm.
Ideally it would be based on a Cerbo GX temperature input.
Any Help would be much appreciated.
MultiPlus Quattro Inverter ChargerchargerGenerator
Andrew Jefferies answered ·
Well.. I have got partway to my answer by using the Charge Control Assistant in the master MultiPlus , Thermal Switch bolted to engine cylinder head, opens when warm. NO extra voltage source need as have used temperature sense input, which has built in pull up resistor..
